Mopar Forums (/forums/)
-   Transmissions, Transfer Cases and Rear Ends (https://moparforums.com/forums/f82/)
-   -   What is correct TorqueFlite transmission fluid for 64 Ply Belvedere 318 (https://moparforums.com/forums/f82/what-correct-torqueflite-transmission-fluid-64-ply-belvedere-318-a-17925/)
Dad-Par Oct 12, 2014 09:14 AM
Just purchased this vehicle (all orig daily driver) and want to be sure I'm going to use correct fluid. Always remember 'Type A'. Is current replacement Dexron/Mercon (progressive upgrade from Dexron, Dex II, III, addition of Mercon etc) correct for today?
DLJ Nov 18, 2014 04:19 PM
There are quite a few oppinions on what fluid to use, I am using DEXRON II on my 1976 TF, most mopar people like type F and ATF+4 is what Mopar recommends now for all transmissions and steering
https://moparforums.com/forums/f82/t...e-727-a-18008/
cliff32ord Aug 7, 2016 01:00 PM
Transmission fluid to use in a '70 plymounth small block
I've got a '70 Plymouth Satellite with a small block 318. Nothing in owners manual as to what transmission fluid to use. Can someone please tell me? Thank you in advance.
RacerHog Aug 7, 2016 05:18 PM
DLJ spelled it out rite their... :)
RCEnterprises Dec 18, 2016 12:08 AM
Any modern trans fluid will work fine in your trans including synthetic. You can also dump in anywhere from 1 quart to a complete fill with straight 30wt motor oil....yes it sounds crazy but works great. I'd stick with 1 quart for a driver since there is no detergent in that old tech motor oil. Your trans will love you forever.
RC
Iowan Dec 18, 2016 08:21 AM
I read an article that you can use hydraulic oil in the older Ford and Mopar trans, thats all type F is with red die.
