Mopar Forums (/forums/)
-   Chassis, Suspension, and Brakes (https://moparforums.com/forums/f83/)
-   -   1969 Road Runner has a squeal on passenger side wheel (https://moparforums.com/forums/f83/1969-road-runner-has-squeal-passenger-side-wheel-17960/)
Matthew Winters Oct 16, 2014 08:16 PM
Hey guys so I noticed the other day that at about 25-30 mph I get a weird squeal from the front passenger side wheel or so it seems that is where. It also seems to get louder the faster you go and goes away under about 25 mph. It almost sounds like a squealing belt. Is that a bad wheel bearing? Is it hard to change out?
RacerHog Oct 17, 2014 05:06 AM
Could be... Or it might be the vehicle is out of alignment...
Rooty Oct 17, 2014 11:42 AM
What is mounted on that side of the engine? Alternator or power steering pump.
If it doesn't squeal just gunning the engine while not moving, it's probably not
a belt unless you have a leak. Then again belts don't squeal when wet, that's
how you test serpentine setups for slippage. Check you belts for glazing, cracking
or separation. If not a belt it's most certainly a bearing or brake issue. Bearings
are an easy change, preloading the bearings requires the right procedure and specs.
Too tight and you ruin everything you've done, too loose and it'll feel like the
steering's all over the road. Go here for the complete story:
http://www.popularmechanics.com/cars...enance/4205243
Matthew Winters Oct 17, 2014 01:45 PM
Yeah I know it's not a belt and I'm sure it's a bad wheel bearing. I might leave this job to the professionals. If I replace the bad one is it smart to replace the other front wheel bearing at the same time? I mean if one wore out I'm sure other would be just about the same.
Mr.4spd Oct 17, 2014 07:02 PM
They're cheap enough and it's an easy job, I'd do them both.
brian7786 Oct 23, 2014 01:59 PM
Not sure if you have done brake work lately...if so, your backer plate may be touching the rotor and causing a squeal....just a thought...
