1972 Roadrunner - how much can I lower the front ?
Hi all
I have a 72 Plymouth I tried to lower 2 inches in the front tonight I jacked up the front I loosened the thouque bolt about 9 full turns then it started to be stiff - so I stopped Is this the way it supposed to do ? HOW much can I loosen the bolt ? will it stop by it self when I can not loosen any more ? Or will it pop out ?? I had read 5 turns loosen/pull bolt out would lower 1 inch 9 turns only lowered it 1 inch ( after bouncing the front) is there more room for me to get it lower ?? |
Sounds cool... I don't have an answer for that question.... :)
not2 inches, it have no suspension travel left
