1999 dodge intrepid 3.2 v6
https://cimg6.ibsrv.net/gimg/moparfo...92a7c3151.jpeg
It’s been sitting since 2011 been moving lil not much. It has ABS light on can I reset it without scan tool |
If its a "soft code" Once you fix the issue with the ABS system. You can drive it and it will clear on its own. But fit it is a "Hard Code" Then you will need a scantool to clear the fault.
Intrepid
(Post 151798)
Originally Posted by Asan
(Post 151801)
It has about 15-20 codes. There’s air in the system the front drivers side caliper bleeder screw is seized. Plus the car brake lines rusted and replaced them all the way around
(Post 151807)
Oh My... That sounds like a fun one to fix.
| All times are GMT -7. The time now is 01:11 AM. |
