64 D200, V8-361 Clutch Slave Cylinder
Old Aug 19, 2020 | 08:34 PM
Mezrein's Avatar
Can anyone give me any details on replacing and correct bleeding procedures on the clutch slave cylinder. Mine went out, I replaced it with an OEM, and when Im bleeding I cant get air to come all the way out of the system, seems like it keeps sucking back in from somewhere. Also, the piston doesnt appear to move, at all. Have I connected something wrong? Anyone got a good document or youtube video on replacing the slave cylinder? Really drawin a blank
On a side note, randomly, the ignition doesnt seem to want to work, at all. I've replaced the battery, starter, and ignition switch itself. After the ignition switch, went a solid month before the problem came back.
Anything helps, any questions please ask Ill do my best to answer!
Old Aug 20, 2020 | 07:47 AM
Make sure all the lines and or hoses are all in good shape>>>> Make sure you have the Clutch Master Cylinder rod adjusted for full travel>>>> You mite have to use a pressure bleeder? But You should be able t bleed it just like bleeding the brake system.
Good Luck... Keep us posted...
Old Aug 20, 2020 | 07:30 PM
Mezrein's Avatar
Complete and utter failure. Picked up a pull bleeder, just keeps pulling a mix of fluid and air, clutch peddle goes all the way to the floor and gets stuck and does not return unless you bump it with your foot/hand..
Old Aug 21, 2020 | 07:05 AM
The Pedal Assembly should have a return spring attached to keep it from staying on the floor.
What is connecting the Slave to the Clutch Master Cylinder? is it a hose or a tube?
Hope this helps... Keep us posted...
Old Aug 21, 2020 | 08:39 AM
Mezrein's Avatar
Its a metal tube, probably 8 to 10 feet long with several loops in it. I picked up a syringe style vacuum thing that I tried yesterday and got my failure then retried again today, long slow process but seems to be working ish? Id like to get one of those pressure bleeders like shown in the video, but dont really wana spend 55 bucks on it. Might have to though, this is starting to drive me nuts.
Old Aug 21, 2020 | 03:38 PM
Mezrein's Avatar
Good news! Finally got the damned slave bled AND working correctly.
Bad news, started the truck and now oil is spewing from the topside, back, center of the engine... And I cant figure out where the heck its coming from since its slightly behind the firewall. I dont even know what would be sitting in that area.
Old Aug 22, 2020 | 06:55 PM
I think the Oil Pressure Sender / Maybe yours has a manuel gauge line? is in the back of the engine... Use a small Mirror and a flash light and see if you can see whats up back behind there... Use you cell phone camera if you can !!
Like we say.... 1 step forward and 2 steps back !!!
Old Aug 23, 2020 | 09:07 AM
Mezrein's Avatar
Yup, its the oil pressure gauge line, discovered it yesterday, just thought the tube was lose, nope.. the rubber tube and center plastic tube inside was broken........ Im really, really not wanting to have to pull that whole line, its tarred into the firewall, which Im pretty certain Id have to replace that as well. Im thinking I might just get a plug and plug it..... Thoughts?
Old Aug 23, 2020 | 03:20 PM
Its your project, and your budget.... Myself... I dont shy away from work... I rather have the information....
Old Aug 23, 2020 | 09:27 PM
Mezrein's Avatar
Well after a lot of grunting, snarling and fighting, my nephew and I were finally able to replace line, we're not sure how things were going wrong in some cases, but we managed to do it. No more leaks, clutch working great, although peddle kind of short now but thats ok I dont like a long clutch anyway, and seems to run mostly smooth. I want to give a big thank you to you Bob, that was my dads name btw, for all your assistance and being the only one to respond in the thread, kept me going.
Thanks again so much.
Old Aug 23, 2020 | 09:30 PM
Mezrein's Avatar
Well we finally got it, through a lot of grunting, snarling and not being able to figure out why something was working when as near as we could tell it shouldnt be, my nephew and I were able to get her back up and running. Clutch is smooth, no oil leaks, all good to go. Want to say thank you Bob, was my dads name btw, for all the assistance and being the only one to respond to me in here. Was very much appreciated and really kept me goin and motivated me to not give up.
Thanks again.
Shawn
Old Aug 24, 2020 | 12:47 PM
Shawn, You are welcome... Glad you got it fixed and are able to maybe drive it some and enjoy the hard work you put in.. I'm sure the fix it list is long. But a little at a time can really make an improvement.. Mopar on... Love them old 64's..
Keep us posted on what you do next at some point....
Cheers
Old Aug 24, 2020 | 02:18 PM
Mezrein's Avatar
So you can see what you've been assisting with
Old Aug 29, 2020 | 06:09 AM
This was my old 1968 Dodge D200.... 440 with a 727 Trans.....
DonRobs
Sep 23, 2013 03:52 AM
DonRobs
Aug 15, 2013 08:15 PM
Desperota 488
Jul 20, 2013 03:58 PM
74bbroadrunner
Mar 17, 2011 09:53 AM
ChallengMe1973
Aug 12, 2008 03:19 PM
