69 barracuda brake conversion
Old Jul 12, 2015 | 01:08 PM
Candy green 73's Avatar
I wanna do a disc conversion in my 69 barracuda 1 reason is I want to have the 5x4 1/2 lug pattern instead of the 4 inch they don't sell any nice wheels in that pattern also I just want the reliability of disc does anyone now of a budget conversion I can do
Old Jul 12, 2015 | 02:05 PM
73 up A body disks
Old Jul 13, 2015 | 09:45 PM
moparted's Avatar
and he will still have sbp on the rear?
Old Jul 14, 2015 | 02:32 AM
69 barracuda
Yeah want the 5x4 and a half through out the whole car
Old Jul 14, 2015 | 04:35 AM
Then you will. need new axles and drums for the rear drilled for 5 on 4 1/2.
Old Jul 14, 2015 | 05:53 AM
69 barracuda
Should I grab a full rear end of will the axles fit in existing rear end
Old Jul 14, 2015 | 09:22 AM
Drag Pak's Avatar
Remember "A" body drums and axles are narrower (bearing to flange) than the others.
I believe mopar mentions the conversion to stock later model front disc brake assemblies will widen the track about 3/4" per side . The wider front track gives the appearance of crabbing from both sides!
I have had a small pattern set(axles and drums) drilled to large pattern using "A" body the 7/16 wheel studs that worked great.
It may be a better (but $) route to do a complete disc kit on all four corners.
smackhonda
May 19, 2010 03:02 AM
Hollonator
Mar 2, 2010 11:20 AM
Stockdog
Sep 8, 2008 07:50 PM
kszysio
Jul 24, 2008 03:24 AM
BTKBraden
Feb 22, 2007 11:31 AM
