Mopar Forums (/forums/)
-   Chassis, Suspension, and Brakes (https://moparforums.com/forums/f83/)
-   -   aftermarket brake pedal assembly (https://moparforums.com/forums/f83/aftermarket-brake-pedal-assembly-15753/)
383mopar Sep 4, 2013 12:04 AM
Does anyone know of any aftermarket brake pedal assemblies that have a shorter gap to the floor than the stock brake assembly? I have limited mobility in my ankle, that's why i'm asking.
TVLynn Sep 4, 2013 11:28 AM
DO you have power brakes ? Pwr pedel is much closer to the floor than manual brakes
RacerHog Sep 4, 2013 01:02 PM
You could go to Hand-Control, If it's a handicap issue....
http://www.mcmobilitysystems.com/Mob...ls.aspx?ID=128
Respectfully
Bob Hogan
383mopar Sep 6, 2013 12:02 AM
power brakes are a good idea but i have to figure out how that system would work with a tunnel ram. as far as hand controls go, my problem is not as severe to have to resort to that. i have driven other vehicles before, but i would like to feel more comfortable in my mopar.
RacerHog Sep 6, 2013 05:33 AM
Easy enough..... Cut the pedal and reweld a braket to set the pedal where you like it..... And your done and ready to ripp it up again...
TVLynn Sep 6, 2013 12:06 PM
No vacuum with a tunnel ram. SO for power brakes you would need some type of electric vacuum pump.
IF that is not low enough YOU need the hand controls !!!
I would not cut the peddle. If any type of accident happened ? could have big problems
RacerHog Sep 6, 2013 12:12 PM
Just remember...You will have limited travel....
Oupps..Almost my bad... :)
