broken hub
front right wheel hub broke on my 65 today, went to autozone and they dont carry the part, wheres a good place to get a hub?
3 Attachment(s)
heres the damage
Ouch... Dont want to know what preceded that problem, or even what happened after the failure, but a quick Google search brought up this link,http://www.eteamz.com/LincolnClutchB...cfm?cat=541249
You hafta scroll down to the "Dodge" section, and they have a few listed for various models. After that a junk yard etc.... |
woah. serious pothole huh?
actually nothing happened thank god, i was just cruising along the highway when the i could feel a slight vibration and i pulled over just in time to discover this.
dang still no luck on finding it, does anyone have any hubs for 65 coronet laying around?
I have several hubs for a set of 66 brakes, off a coronet, do you have a good one for measurement?. Or some way to cross referance what swaps? My guess is that the spindle measurements will be what is important. The hub itself will be cheap enough to ship.
I would say a drum assembly of the same size brakes should fit. I believe the trucks are different . I would guess some improperly pressed studs may have contributed to your problem. If you can fine one ? check an old Hollander interchange manual
According to the link 1/2T trucks are the same.. 1965-69 Dodge Full Size (Front Drum) (NWRA # X-21458) Qty. 5 IN STOCK!!! I put some early 60's Chrysler 11" drums on a 66 Coronet, bearings are pretty standard |
(Front Drum) (NWRA # X-21458) Qty. 5 IN STOCK!!! This link is for drums. sgp7679 is looking for the hub. Drums will fit more applications. Such as b-body and c-body but the hub will be smaller on the b-body.
