converting a 1957-64 1820657 or a 741 8.75 rearend to disc brakes
has anyone found the right conversion kit to change a 1957-64 8.75 741 rear end to disc brakes?
welcome
i have not researched that particular year. but have you tried summit racing? |
Uh your talking about the rear end where you have to use the special puller to remove the rear drums?
If you insist on rear disk brakes I would look at some of the Big Ford disk setups and adapt a 9" rear.
| All times are GMT -7. The time now is 02:46 AM. |
