front brake hub seal
Old 05-01-2017, 05:07 PM
t65fury3's Avatar
hello i have a 1965 plymouth fury lll 318 motor I'm looking for the front outer wheel bearing seal .maybe a part number might help locals show nothing
Old 05-01-2017, 07:30 PM
There is an inner seal but NO outer seal SO inner seal,bearing, rotor/drum, bearing, castle nut and dust cap
Old 05-01-2017, 10:38 PM
t65fury3's Avatar
thanks for the reply saw the book and just double checking the dust cover is the cap .what a time finding a hub someone before thought beating on the hub where the inner bearing goes was a good idea totally screwed it up.found a used one but what happened if i needed a new one .could not find one might you know where just in case the passenger side is bad but i think i did work on that one just wanting to be sure ill check later lots of stuff going on.again thanks so much.
Old 05-14-2017, 02:48 PM
t65fury3's Avatar
one side down one to go then is registration time
dodgem880
02-04-2024 01:14 PM
demetri
02-26-2014 07:32 PM
Shrug
03-26-2013 04:41 PM
DodgeRamFan23
04-09-2011 07:33 PM
Dave E
10-07-2010 05:18 AM
Quick Reply: front brake hub seal
