Low master cyl bleeding issue
Are there any special tricks for bleeding a 4 wheel drum setup with a frame mounted master cylinder? 4 of the wheel cylinders are higher than the m/c and we're having problems getting them bled. When using a vacuum bleeder the flow doesn't continue once the vacuum is turned off, even when the drain line is lower than the m/c.
Dave |
Dave... Use a Pressure Bleeder.... That should get it handled for you....
Something like this one, with the rite lid... :) http://www.nationaltoolwarehouse.com...13332C469.aspx |
| All times are GMT -7. The time now is 08:33 AM. |
