Master cylinder
I've installed 4 wheel discs on my 70 charger 500. I'm staying with the power booster which has a four bolt mount to the MC. Most of what I see aftermarket are two bolt mounted master cylinders. Is there a good disc / disc MC with a 4 bolt mount so I can avoid the adapter? What have you used, what do you like?
