Rear spring - Dodge Polara 1964
Hello,
I have a question for you. What leaf springs would you recommend for my Dodge Polara 1964. (original engine was 383, now the car has 440 cui) I don't know what maximum load on the vehicle I should use so that the car is not too hard or on the contrary too swayed, in short, to be just right. Thank you for answer. Jiri Deak |
I would Check with these folks to see what Available >>>>>>>>>>> https://www.springsnthings.com/
Could you send me a link of summit racing leaf springs that you would recommend?
I don't know what maximum car load I should use. 3200 lbs or 3800 lbs? |
Bob’s answer is probably your best bet, contact them directly to figure out what you need.
Ok, thanks you 🙏🏻😊
| All times are GMT -7. The time now is 06:41 AM. |
