Steering Noise, grinding
re 1997 Cirrus 167,000 mi
Just starting hearing a metal grinding noise when the steering hard either left or right. I raised the vehicle for a quick inspection but wasn't able to find any obvious sources. And, I wasn't able to produce the grinding sound when the wheels were off the ground. There are no other steering or drivability problems. I plan to recheck today with better light conditions and need some guidance on what to inspect. |
My guess would be CV joints.
If it has a sway bar check how close it is to the steering rods.
Check the steering rack mounting bushings
Originally Posted by Nadir Point
(Post 94788)
Cv joints
