Thick Oil Coating Rear Brake Shoes and Drum
Old Nov 16, 2021 | 06:37 PM
6T8 Charger's Avatar
I bought my 1968 Dodge Charger project in August 2021 and today I removed the rear tire and pulled off the right rear drum and was stunned to see the shoes, springs and drum coated with thick oil/grease. Never seen anything like it. What would cause that? It is bad.
Old Nov 17, 2021 | 02:02 AM
Is it gear lube?
Old Nov 17, 2021 | 05:34 AM
I think so. Maybe a rear axle seal gave way a long time ago. I hope those aren't hard to replace.
Old Nov 21, 2021 | 03:11 PM
Lostviking's Avatar
Go online and watch a video. It's not hard to pull the axle on an 8-3/4 if that is what you have. It could have been leaking brake fluid that was never attended to also. Check the master cylinder and see if it's leaking.
dodgem880
Jan 13, 2022 09:19 PM
Jdaugherty
Feb 1, 2021 03:06 AM
breckjar
Sep 28, 2011 09:36 PM
first64dodge880
Sep 28, 2010 10:34 PM
afastcar
Dec 18, 2008 04:15 PM
