Mopar Forums (/forums/)
-   Chassis, Suspension, and Brakes (https://moparforums.com/forums/f83/)
-   -   Thick Oil Coating Rear Brake Shoes and Drum (https://moparforums.com/forums/f83/thick-oil-coating-rear-brake-shoes-drum-24299/)
6T8 Charger Nov 16, 2021 06:37 PM
I bought my 1968 Dodge Charger project in August 2021 and today I removed the rear tire and pulled off the right rear drum and was stunned to see the shoes, springs and drum coated with thick oil/grease. Never seen anything like it. What would cause that? It is bad.
Iowan Nov 17, 2021 02:02 AM
Is it gear lube?
6T8 Charger Nov 17, 2021 05:34 AM
I think so. Maybe a rear axle seal gave way a long time ago. I hope those aren't hard to replace.
Lostviking Nov 21, 2021 03:11 PM
Go online and watch a video. It's not hard to pull the axle on an 8-3/4 if that is what you have. It could have been leaking brake fluid that was never attended to also. Check the master cylinder and see if it's leaking.
