1970 challenger rt ignition problem
got a 1970 challenger rt with a 440 six pack and it had electronic ignition but it was all wired wrong so I changed it over to points ignition, just wondering how do I go about doing this, not sure how to set it up and help is appreciated!
Best thing I did and would advise is get a good manual with electrical wiring schematics. That way you know exactly what goes where. If you have the bucks go but the correct harness for your application
Originally Posted by knahavasu
(Post 102875)
Set the points at .017" on the high point of the dist. lobe. make sure there is a little dab of grease on the leeward side of the lever/lobe contact point
| All times are GMT -7. The time now is 02:41 AM. |
