1970 Dodge Coronet - No Crank, No accy Power
Old 08-19-2018, 01:54 PM
70Del493's Avatar
1970 Dodge Cornet with a transplanted 440 in it. Was running fine, no issues.
The other dat the Fuesable link that runs from the Starter Relay to the Firewall connector went.
I replaced it and it was starting running fine.
Last night, started fine, drove fine, car did not run hot.
Stop for ice cream, come out, turn key and nothing. I have lights, horn, I have 12 v to the starter relay.
I jump the starter relay and the motor turns over.
Inside, when I turn the ignition to the "acc" point I have nothing, no fan, gas gauge or aftermarket gauges, When I go to start it, I have nothing.
I replaced the starter relay today, that did not help... again 12 volts to, and I can jumper it to get the starter to engage.
I checked the fuse panel, the accy fuse is fine, I replaced it just incase... still no power or crank.
Any and all suggestions appreciated.
Old 08-20-2018, 08:35 PM
Amp Gauge....
70roadrunner383
09-15-2016 05:22 AM
Panderz
06-30-2016 11:42 AM
duster3
10-02-2013 02:46 PM
70newport
08-19-2012 10:39 AM
blazer
07-03-2010 04:07 PM
Quick Reply: 1970 Dodge Coronet - No Crank, No accy Power
