1970 Dodge Coronet - No Crank, No accy Power
1970 Dodge Cornet with a transplanted 440 in it. Was running fine, no issues.
The other dat the Fuesable link that runs from the Starter Relay to the Firewall connector went. I replaced it and it was starting running fine. Last night, started fine, drove fine, car did not run hot. Stop for ice cream, come out, turn key and nothing. I have lights, horn, I have 12 v to the starter relay. I jump the starter relay and the motor turns over. Inside, when I turn the ignition to the "acc" point I have nothing, no fan, gas gauge or aftermarket gauges, When I go to start it, I have nothing. I replaced the starter relay today, that did not help... again 12 volts to, and I can jumper it to get the starter to engage. I checked the fuse panel, the accy fuse is fine, I replaced it just incase... still no power or crank. Any and all suggestions appreciated. |
Amp Gauge....
