Mopar Forums (/forums/)
-   Interior/Exterior Electrical (https://moparforums.com/forums/f84/)
-   -   2008 dodge avenger sxt (https://moparforums.com/forums/f84/2008-dodge-avenger-sxt-25502/)
Truhomie403 Aug 23, 2024 03:33 PM
I have a 2008 dodge avenger sxt I need some help. My passenger front window will not go up or down from the driver side but you can put it up and down on the passenger side. Drivers window is also it will stop working at times then you have to beat on the door panel and it'll start working perfectly again. The passenger window use to work perfectly until window regulator broke and I replaced it. Has auto front windows.
RacerHog Aug 24, 2024 07:00 AM
Could be the driver door master switch is bad.... Or maybe the wiring at pivot area has a wire going bad.. That all providing the rest of the harness is in good shape?
dkoxla Feb 8, 2026 01:28 AM
We have 1 and our engine light has come on and sometimes the car goes flat do you know what the problem could be?
192.168.100.1 192.168.1.1
