67 fury 3 "click click click" sound
Hello, I have 67 fury III when i start her up i have click click click sound and starts sometimes. But recently it doesn't start at all. I've put new battery, alternator, regulator except starter. It might b the problem? if i have to take it out do i have to go through alternator belts and stuff???
what size engine do you have? and yes it sounds like your sarter gave up on you simple test you can try is to tap not pound on the starter with a hammer. if it starts then the brushes are sticking and it is due either replacement or a rebuild.
Starter's bad. Those are the signs. Replace the starter and you should be good!
Thanks again guys
no problem.
| All times are GMT -7. The time now is 05:25 AM. |
