72' Dodge Coronet Custom starting/ wiring problem?
Having problems starting my car. I replaced the starter alternator and ground cable a battery with new terminals and it started for a little bit with no problem and now it has to be jumped every time I start it.
someone throw me a bone here |
Bad ground?
(Post 158262)
Bad ground?
https://cimg4.ibsrv.net/gimg/moparfo...449fab66a5.jpg
https://cimg6.ibsrv.net/gimg/moparfo...cc6ac34728.jpg https://cimg7.ibsrv.net/gimg/moparfo...c3bfec9afb.jpg https://cimg9.ibsrv.net/gimg/moparfo...ff6930ed79.jpg https://cimg5.ibsrv.net/gimg/moparfo...1ba58a1155.jpg THe starter and alternator are new as you can see and the ground and terminals |
Jumped as in the battery is dead? or Jumped as in at the starter solenoid?
If it is at the solenoid. Check the Neutral safety switch. Also. Check the yellow wire on the starter Solenoid and see if it ig getting power when you turn the ignition switch into the start position? |
Jumped the battery. It acts like it doesn't hold a charge. I will try tomorrow to see if the yellow wire on the starter solenoid is getting power
OK.... So every time you go out to start it,,, it will not turn over and the battery is dead?
No it wants to start but what happens is it doesn't so I have to give it a jump it's like the battery is low on charge and then it'll die while I'm turning the ignition over
Time to Load test the battery and see if it has 750 CCA like the label says
