Mopar Forums (/forums/)
-   Interior/Exterior Electrical (https://moparforums.com/forums/f84/)
-   -   77 Tradesman Insrument Cluster Lamps (https://moparforums.com/forums/f84/77-tradesman-insrument-cluster-lamps-21977/)
Timbo Dec 29, 2018 12:24 PM
Hi again folks, I've been quiet for a while - finally found a bush for my steering column and got it reinstalled. The original column switch wiring had been cut, twisted and taped! Not the best - so I used crimped bullet connectors, a much neater job. Please note the connectors need to staggered to enable the cowling to sit nicely.
Anyway, after doing all that I noticed my lh blinker on the dash wasn't working and so removed the dash and found 4 bulbs blown, the cluster push in types. What I wanted to know is what each of the bulbs do? I get the blinkers, the high beam at the top, but what do the rest do? I also have a bulb - loose on a long wire, which tells me I'm in park or neutral, whereabouts should that be on the cluster?
All replies greatly appreciated.
Timbo.
RacerHog Dec 30, 2018 10:46 AM
Post up a photo Tim.... Good to have you back... :)
Timbo Dec 30, 2018 11:21 AM
Thanks RacerHog. Will do, be after NYE now . . . Wish all of you members a great 2019 from us lot across the pond! 🍾🍾🍾
Iowan Dec 30, 2018 11:26 AM
You start just a bit earlyer there, have a safe holiday!
Timbo Dec 30, 2018 11:56 AM
We do yeah, my pal in Australia gets it first! We start in just under 24hrs! Thanks Lowan, you stay safe too . . . 👍🍾
Iowan Dec 30, 2018 01:51 PM
That's Iowan from the state of Iowa U.S.A. thank you very much. 🙂
Timbo Dec 30, 2018 02:16 PM
Ooops! Sorry Iowan! Thought it was an lowercase l, my apologies sir! Have a great 2019 👊👍🍾
