Brake lights don't work!
Alright here's my dilemma..my brake lights won't work..my regular lights and turn signals work, and I replaced the brake light switch and have power to both of the prongs on it...I'm guessing that the wire is bad somewhere to back..but I'm never sure..any help is appreciated!
I would check the steering column harness. The bottom of the column has a large connector that the brake lights run through. It may be loose or melted. If nothing else it's a good place to start your investigation with your meter. Check out your FSM for other body harness connectors, I think there's one more between the column and the bulbs. Good luck, and happy hunting.
I had the left brake light not working and both turn signals working. Turned out to be the turn signal switch. Check the harness and connections but if you don't find anything take a close look at the switch.
I'm not a fan of overlays unless absolutely necessary.
Always try and find the area the wire is messed up and correct it accordingly.
Also, have you checked the bulbs? If it's a dual filament bulb, that could be your issue. The chances of both blowing at the same time, not likely.
But you never stated you checked them, and you never stated if they both went out at the same time.
Here's how all turn signals work on these cars, exempting imports and some new US vehicles with SEPARATE stop and turn lamps
Power goes to the brake light switch from a "hot" fuse, IE key does not have to be in either run or accessory
When the brake switch is activated, it sends power up to the column, the turn signal switch
The turn signal switch ROUTES the brake switch power
If signals are OFF, (centered) BOTH rear turn lamps receive brake lamp power
If signal is to one side, whichever turn signal lamp is selected is PREVENTED getting brake switch power so that the turn signal can flash
If you are getting power from the brake switch up to the column AND both turn signals work properly (flash)
THE TURN SIGNAL SWITCH is bad
"Back in the day" (when I was young and stupid) and long before Al Gore invented the www, or we "kids" figggguuured these cars would be worth somethin', I devised a "workaround" for some switches
I discovered that on the newer cars, which have the 4X switch incorporated into the column switch, that I could break off the 4x button (to prevent it from being activated) and move one wire, or jumper one wire, (My senile mind forgets) and "fix" the turn signal switch.
So you ended up with no working 4x flashers, but at least the signals and brake lights work. DO NOT ask me how I did this. This was FORTY years ago!!!
Blue - all rear lights work, turn signals and flashers work too so it can't be the bulb
440 - im gonna take a wild guess and say the turn signal switch is in the steering column?..how difficult is that to replace?
!! NO !!
I love this guy. Awesome knowledge.
I am neither party, but the turn signal switch is a little tough to replace, as you have to remove the steering wheel to get to it. With a Steering wheel puller, and the other correct tools, its not really hard to do, just kind of a PIA to have to do it....
And its been about that (years wise) for me too...
Generally you need a wheel puller and if you have a front balancer puller, you can use that:
The turn signal switch is right there "on top" but the caveat is that some trim parts won't allow the harness connector to come out without tearing things apart, depending on the car model.
FRANKLY I would not be the least bit adverse to cutting the wiring off the old switch close to the switch, so you now have a connector with a long pigtail. Then cut the connector off the new switch about an inch from the connector, so you can see the wire colors if necessary.
If you do a good job of connecting with "butt connectors" nobody will ever care.
Be gentle, NO prying!! IF you get all the proper screws, etc, out, it will come right out.
OK it could be the bulbs that is where I'd start the next would be fuses after that be sure to check your grounds and if its none of them check for broken or frayed wiring starting at the brake light sockets and working your way towards the front of the vehicle. it could also be the brake light sockets also.
cuda341
Aug 30, 2018 06:32 PM
Steven Bowers
May 9, 2010 01:10 PM
ef8340
Dec 17, 2008 12:07 AM
