dash electrical
69 charger.
I just replaced the turn signal mechanism. It fried itself :) with the new one the passenger front signal is dim. brake light were out, but I bypassed them. Also dome light is out. IT is super frustrating!!! When I turn the lights on the right turn signal lights up. This is with the key off....Also the right blinker blink both tail lights when the lights are off |
You're definitely getting a back feed. Many back feeds are caused by a bad ground. Power will search out seeking a ground and often uses a bulb. Check your grounds and bulbs that work off that circuit. The bulbs sometimes get corroded and cause this as well.
