Fender mounted turn signals
Was thinking of installing a these on my 68 Fury which didn't come with them originally.
Does anyone know how these would wire in? The existing harness does not appear to have any provision to just plug them in after a quick look the other day. Any help much appreciated. |
Originally Posted by dsikkema
(Post 118165)
Does anyone know how these would wire in? The existing harness does not appear to have any provision to just plug them in after a quick look the other day. Any help much appreciated. Your only option is to look at it and find the positive wire and negative wires that feeds each turn signal on the front of the car and tie into those wires. They might be yellow and Tan. Cheers |
Not sure how Dodge did it, but most others wired into the hot lead going to the turn signal (cut the wire and attach the fender mount to complete the circuit). This allowed the fender mount to indicate if the bulb burned out, as it wouldn't have a complete circuit and would not even light.
I would check a little further my 68 didn't come with them either but I do have the plugin in my harness
They had them in 67 on Polara and Monico's and such.....
Just tie them into the front T/S they will work just fine.... Dont cut the wire if you dont have too... Just make a y-connector to connect it all together. |
There may have been actual different turn harnesses in the engine by. Originally they DID "plug in."
I still miss the ones on the hood on my '70. Hell I miss my 70!!! But I can't afford one anymore |
Originally Posted by 440roadrunner
(Post 120506)
I still miss the ones on the hood on my '70. Hell I miss my 70!!! But I can't afford one anymore I know the Feeling..... :( |
| All times are GMT -7. The time now is 08:38 AM. |
