Mopar Forums (/forums/)
-   Interior/Exterior Electrical (https://moparforums.com/forums/f84/)
-   -   Fuel sender (https://moparforums.com/forums/f84/fuel-sender-15957/)
Shrug Oct 7, 2013 10:24 AM
Fuel sender
I have a 1952 Plymouth Cranbrook. The car has been converted to 12V
I thought the gas gauge was working. When I fill the tank it goes all the way over past the full mark. After it gets down a few gallons it just drops to E
Does it matter if 12 or 6 volts are going to the gauge?
Before I spend the money on a new sender should I try a dropping resistor in the gauge?
Thanks all.
Shrug Oct 10, 2013 07:18 PM
Anyone? Please?
Coronet 500 Oct 10, 2013 07:47 PM
A resistor should work, which one not sure, been quite awhile since I've had to do those type of calculations. I'll bet there is some calculator for just such a thing on line somewhere.
440roadrunner Oct 10, 2013 10:20 PM
Of course "it matters."
First of course, there may actually be something wrong, think of gauges as an end to end system.
Plot the path in your mind "how they work" and how they are hooked up. They are generally a long, series circuit, so any break or loose connection along the way will break the whole chain
Google "runtz" instrument regulators. These are used, one each for fuel, temp, and oil for 12/ 6V conversions.
http://www.speedwaymotors.com/Runtz-...cers,2374.html
