Head lights not working
i got a 2017 challenger 3.6 l My high and low beams are out.The day time lights work which i assume are the rings around the headlites but the headlights do not come on at nite any ideas on this?
Not even manually?
no and im not sure if i have hid headlights because each fuse box location i see it shows 2 yellow 20 amp fuses next to each other and i dont have those two.
Check the bulbs..... One style has the later model Standard looking style bulb similar to a 9004...
The HID's : Some have a square box hanging off the back of the bulb... Check for power at the connectors with the light switch in the on position... |
Yup, I was just going to suggest bulbs but Racerhog beat me to it. I recall replacing and doing all kinds of stuff on a Dodge van with no low or high beanms only to find out they blew out when the customer hit a pothole.
I would verify the high/low beam switch, in the older cars low beam goes out when bad not sure about this but I would check it out.
would 1 blow headlite bulb make the other dead too, im asuming not?
No
i dont have those 2 yellow 20 amp fuses for hiv headlites i also dont have relays 46 and 65 so im lost now.
Check the headlight ballast.... Maybe they are losing power when they warm up????
I owned a 17 Challenger SXT also. Check fuse #15 and #15.
im told the 2 fuses 40 amp in the trunk , to check those but they look like square little fuses, not the normal type what kind are they.
Originally Posted by Lostviking
(Post 162090)
