Mopar Forums (/forums/)
-   Interior/Exterior Electrical (https://moparforums.com/forums/f84/)
-   -   Need a replacement steering column harness connector (https://moparforums.com/forums/f84/need-replacement-steering-column-harness-connector-21842/)
Vitamin C Nov 1, 2018 01:54 PM
The 8 pin connector is burnt in the middle from the main red power wire and need a replacement set-up. I looked on line for any flat 8 pin connector that can handle 12 awg but no luck.
I don't want to buy the aftermarket turn signal that comes with the wiring harness either.
Any help would be greatly appreciated on where I can buy the male and female connectors with the new pins.
https://cimg5.ibsrv.net/gimg/moparfo...15431b6a3.jpeg
Vitamin C Nov 1, 2018 02:15 PM
I actually found an 8 pin harness connector that should work, it's made by American Autowire part # 500428
Not the same but it will work if I replace both sides.
Here is the dash harness side.
https://cimg8.ibsrv.net/gimg/moparfo...ece85f85c.jpeg
Vitamin C Nov 3, 2018 01:39 PM
This is the ignition switch connector that is burnt up and wish they made a replacement one but I have had no luck.
RacerHog Nov 3, 2018 03:24 PM
I have just used what ever has been avalible at the time. I like the Standard or the BWD..... As for the Harness Side, I just use whatever makes it works. Bullet connectors from Lawson Products work well for me in the past.
