Mopar Forums (/forums/)
-   Interior/Exterior Electrical (https://moparforums.com/forums/f84/)
-   -   Wiring For Pertronix Parts (https://moparforums.com/forums/f84/wiring-pertronix-parts-24744/)
Mopar4Life90 Sep 2, 2022 02:47 PM
Hey guys, so before I go any further, I want to say that I do not have the best knowledge in wiring. With that being said, I have a ‘79 Dodge with an LA 318 that I installed a Hughes Whiplash cam along with Pertronix Digital HP Module, Pertronix Distributor FlameThrower II, and their FlameThrower II Coil. I have the wiring correct for the module to the distributor and coil. And I had the ignition wiring going to the “IGN ACC” fuse.
I have the power getting to the module and truck turns over but no spark.
I have the original ignition module (4 Pin) still hooked up and the dual ballast resistor. Is there any other wiring I’m missing? Is the ballast resistor not needed (which I’ve read)? Any help, or diagrams would be helpful. I’ll put the diagrams I found up that maybe could help all of us get on the same page.
https://cimg2.ibsrv.net/gimg/moparfo...bb9de8d32.jpeg
https://cimg5.ibsrv.net/gimg/moparfo...bc66b16fd.jpeg
RacerHog Sep 3, 2022 08:56 AM
Check to make sure that you have 12 volt when crank the engine over on the Ign Acc .....
sallyrenme01 Apr 29, 2025 01:18 PM
Get one from pull a part with same part # . They don't have to have the vin programmed like people say. I have swapped one and everything worked fine
192.168.100.1 192.168.1.1
