Interior Door Liner Installation
My 67 Coronet 440 came with newly upholstered door liners, but not installed. I have the clips for installing. The problem is the liners have all the holes cut in them along the lower and forward and aft edges for the clips but are not there along the upper edge. The door itself has seven holes for the liner installation along the upper side. What would be the best way to locate these holes in the liners?
Thanks, John |
on my valiant there is a metal strip that holds the upper part of the door panel. i'm not sure if your car is set up the same way or not. but more than likely it is. measure the distance from the top to the bottom holes on the door panel and from the top holes to the bottom holes on the door its self.
| All times are GMT -7. The time now is 05:47 AM. |
