roadrunner trunk pan
hey guys . the trunk pan has reached its life expectancy. i see u can get a 1 piece or also a 2 piece pan. any thoughts on which is best . thanks again on the advice.
I say 1 piece, less welding, looks better, and with out that center seam to hold moisture it, will not rust out as fast as the 2 piece.
If you are going to do it yourself, Maybe the two piece pan is just easier to install, But as mr340 said I think a one piece is just better..So you make the call.
1 piecee requies removing the tail panel
thanks a million guys. just what i wanted to hear. sounds like the one piece is the right way to go. gotta pull one quarter off anyway .
