Trunk pan replacement ?'s 69 Satellite
Could use some help from the body work experts.
I fully removed the old trunk pan drilling out all the old welds, prior to receiving my new pan. My issue is; The new pan does not hav a 90 degree downward bend at the very rear, where it would weld to the rear valance. Would I simply weld the pan where it butts against the valance? If so, should I cut off the valance where it extends past the pan or fill the holes I drilled. Any help would be greatly appreciated, as this is my first ever project and I have no clue what I'm doing...... :) |
| All times are GMT -7. The time now is 06:56 AM. |
