window help
Old Sep 13, 2012 | 08:09 PM
mikerp76's Avatar
window help
my passenger side back window is hard to roll up and down. i know the regulator probably just needs to be cleaned up and relubed. but how do i get access to it? do i need to remove the rear seat in order to pull the side panel or not? and where can i find the window rubber for the front and rear windows? thank you for your help on this. i forgot to mention it is on my 67 valiant 2 door coupe.
Old Sep 13, 2012 | 09:13 PM
You do need to remove the seat to get the side panel off. I have drilled a small hole to inject some grease, make sure it is warm so it flows better, worst case, I have taken the guts out of a good regulator to fix the non working one. Just drill the rivets
Old Sep 14, 2012 | 05:22 AM
mikerp76's Avatar
t's what i thought just wasn't ure if there was an easer way to do it. it works just a little stiff. but if i roll the window up and daown a few times it gets easier for a few minuets then goes back to being stiff again.
Ragtopdown
Nov 1, 2017 09:31 PM
staledog
Nov 25, 2010 06:53 AM
Baluchitherium4
Dec 8, 2008 09:47 PM
staledog
Oct 19, 2008 08:40 AM
yeao2003
Jan 26, 2008 03:43 PM
