1979 Cordoba Intermittent Wiper motor crank linkage
I'm looking for a 1979 cordoba wiper motor (intermittent) with wiper crank and linkage. Here is a picture of my current setup. I need everything in this picture plus whatever plastic piece that broke off. Contact me at kotd@i29.net.
I found this info regarding compatibility with other vehicles during a search on this site FYI:
piero- your volare has 3 speed wipers with delay. the nylon bushing you show in the picture dries out, cracks and breaks off...this you already know. the nylon bushing is not available as a separate piece, it comes as an assembly attached to the wiper arm transmission (linkage). it is a replace only not serviceable item. this piece is found on other chrysler cars- 80-83 cordoba and mirada, 79 cordoba, 79 diplomat, 76-80 aspen and volare with delay wipers. i know, because mine broke on my 80 mirada. i could not find a used one, so i tried my local dealership- they listed 2 in canada, and i bought one. this was about 2 years ago. at the shop where i work, we just serviced a 79 cordoba with the same problem. when we tried to locate this part, noone had one. i suggest you search for one on the internet, maybe ebay. you could also try www.wiperman.homestead.com . he does not stock this item, but might be able to help you locate one- he is located in st. catherines, canada, but he ships internationally. good luck in your search.
Update: I no longer need the wiper motor, just the wiper crank with the nylon/plastic piece. Please message me on here or at kotd@i29.net if you have this item for sale.
akers72dart
12-06-2014 06:49 PM
atowncris
11-19-2009 01:48 PM
