Carter Carb Bolt
Old Oct 11, 2012 | 08:33 PM
buttton's Avatar
Carter Carb Bolt
I need the two bolts for the venturi assembly, the ones with a hole running through them. For a Carter BBD two barrel. Thanks
Old Oct 12, 2012 | 05:22 AM
Gorts 5th's Avatar
Smile
i have several get me some photos of your bolt and assembly
then we got to figure on how to get it to you
Old Oct 12, 2012 | 08:17 AM
buttton's Avatar
This is the best I can do for now. I can take a pic later and measure the but I was hoping this would give you an idea. NOT the red arrow, the screw above it. I pulled these from the net. Thanks
Attached Thumbnails Carter Carb Bolt-expvw03.jpg   Carter Carb Bolt-idletube.png
Old Nov 16, 2012 | 03:30 PM
moe7404's Avatar
the pic is hard to see. but the red arrow is pointing to the brass idle tube. the screw is higher and more to the left. the brass tubes do NOT come out, dont try to take them out. the float level is 1/4 inch do not use any other foal level.
70TXPlum
Mar 25, 2013 07:17 PM
razalas_89
Jan 31, 2012 04:45 PM
Red Devil
20
Apr 18, 2011 06:05 PM
FS212
Jun 3, 2010 11:50 AM
ken g
May 17, 2009 06:16 AM
