Mopar Forums (/forums/)
-   Part(s) Wanted (https://moparforums.com/forums/f87/)
-   -   Dodge A100 Van driveshaft needed (https://moparforums.com/forums/f87/dodge-a100-van-driveshaft-needed-21320/)
Sunracer Apr 30, 2018 08:13 AM
HI all, need a driveshaft for a 1967 Dodge A100 van. It is equipt with a slant six and a Torqueflite. that would be ideal if you ahve that driveshaft-or one froman application that is a bit longer that I could have shortened.
Thanks for your help!
RacerHog Apr 30, 2018 12:27 PM
https://www.iedls.com/
Sunracer Apr 30, 2018 03:57 PM
well I called them $500- if I could give them all the specs, but I havent got any driveshaft to use and the cost is way too rich for this project
RacerHog Apr 30, 2018 04:29 PM
Stop in to the rear end shop on southfront road OR Bayshore truck and equipment on Vacso rd...
Take a measurement from the rear end pinion flange to the seal on the output shaft of the transmission. That should get you where you need to go in length. them you guys can figure out the yoke and size u-Joints needed for the project.
At least you will have 3 prices and can make a good judgement call...
http://www.dtscustom.com/files/dts-d...order-form.jpg
RacerHog Apr 30, 2018 04:36 PM
Might check with>>>>>>> http://www.dodgeconnection.com/73_93...ruckparts.html
Or
http://www.dvap.com/
