Looking for a Nice 360 LA Small Block
As title says i am looking for a nice 360 Small Block for my 75 Duster i want it to be a drop in and go if at all possible but is not 100% needed. As most i would also like some mods, like a cam, heads, headers, intake and carb etc. along those lines no internal if wanted unless price is great. Ill take a 100% Stock 360 Small Block i will not bother me at all. But heres the bad part it needs to be kind of close to Monroe, LA like within 200-250 miles or it will need to be shipped which i will also pay for if engine is a good price as i am on a tight budget to get this thing on the road soon. Just let me know asap.
Find a magnum junk yard long block and swap your front cover or keep the serp set up and add an e fuel pump. Prob less than 500 bucks. Add an intake and an mp distributer and your off.
That would be cheapest way to get a 350-400hp, 9.1 cr and a roller valve train. Search my old posts if you want to do the swap I have written this up before. Its cheap and very reliable combo. |
i found one at a place in town but they want $400 and i dont know how many miles are on it, plus i want to put a Purple cam with .474 Lift but not sure if stock springs can take that or not.
Update* Found engine and getting it Monday |
Find a roller magnum block. Even if a couple hundred bucks more. The head flow and roller valve train make 350 HP super easy with excellent vacuum and 400 with some bump at idle. Plus you dont have to buy heads just re spring the ones on there.
| All times are GMT -7. The time now is 11:01 PM. |
