Mopar Forums (/forums/)
-   Part(s) Wanted (https://moparforums.com/forums/f87/)
-   -   Need a 4bbl intake with carb for 69 dodge 273 (https://moparforums.com/forums/f87/need-4bbl-intake-carb-69-dodge-273-a-13565/)
jimiheadstone Oct 24, 2012 04:53 PM
looking for a 4bbl intake with carb for a 69 dodge 273 motor.
Would prefer stock intake but aftermarket is ok provided that it will fit the 273.
Email me Donmac34@aol.com
TVLynn Oct 24, 2012 05:28 PM
Edelbrock street master ?? SP2P manifold ??
jimiheadstone Oct 25, 2012 02:25 PM
is it for sale? or are you recommending it?
TVLynn Oct 25, 2012 04:33 PM
Just a suggestion. You don't want to go to large on the intake . Heads have small ports
moe7404 Nov 16, 2012 03:20 PM
the last year for the 273 was 1967. the 340 came out in 1968 as a much hier performance engine. NHRA refactored the HP of the 340 at least 3 times. since you have a 2 bbl carb you must have a 318. if you have a 1969. as the 360 didnt come out till 1970 or 1971.
65Val Dec 13, 2012 04:48 PM
Wrong...273 continued 'til '69...4bbl version stopped in '67, as well as the solid cam....hydraulic cam and 2bbl carb. for '68/'69.
TVLynn Dec 13, 2012 06:08 PM
Dealer friend bought a ? 71 340 RR with a bad engine. Put a 318 in it... So 30 years later anything is possible as to engine Try and read the casting #'s on the side if the block by the starter
moe7404 Feb 28, 2013 08:37 PM
yep i mistakenly thought that the last year for the 273 was 67 cause the 340 came out in 68. oops sorry. a close friend bought a new 68 barracuda fastback, 340, 4 speed. VERY fast. this site is a lot better than some.
jacilynn_s Mar 3, 2013 06:30 PM
might be a stupid question but why put a 4 barrel on an engine that runs better with a 2 barrel on it?
moe7404 Mar 5, 2013 03:18 PM
cause some people think that bigger is ALL WAYS better. a good running engine is a SYSTEM. not a part here and a part there. if you look at ALL the high performance cars by chrysler you will see that the parts on each car is NOT a bunch of misfits. its a system. take a 1965 chrysler 300 L. it is the only 300 with a single carb. thats NOT by accident. same with the rest, a 1966 street hemi, it was not ment to be as fast as a RACE HEMI, so thats what they made. ITS NOT AN ACCIDENT.
65Val Apr 3, 2013 11:15 PM
Are you kidding!!! The 273 2bbl carb is junk!! Obviously, you've never driven one. The AFB 4 barrel for that year is a vastly superior carb, even on the 2 barrel engines. Any 4bbl carb will wake up a 2 bbl 273, Carter or Holley.
moe7404 Jul 13, 2013 08:15 PM
dont forget the 273 4 bbl carb is about the smallest 4 bbl ever made. and it is sized right for a 273. like i said if chrysler made it its a SYSTEM.
