NEED HELP ON AN INTAKE
My father bought a set of Mopar Performance stage VII max wedge aluminum heads from jegs. We cant find an intake to fit it. Supposedly everything was discontinued before it began. Any info would be greatly appreciated.
Edelbrock #2893
(Post 135733)
Edelbrock #2893
2- Thumbs up... :) |
Thanks guys
We talked to some edelbrock people at rod run in gatlinburg tn. They said they dont make anything to fit these heads
What the P# you bought... Maybe we are missing something here... :think:
Try Indy, I thought all the mopar heads were edelbrock.
Call edelbrock tech.http://www.edelbrock.com/automotive/misc/tech-center/
Part number
The part number on the heads he has is p5153823
We tried some intakes that supposedly fit the stage VI stuff but they were way too wide for the raised port setup we have. |
(Post 135762)
http://www.jegs.com/i/Mopar-Performa...53823/10002/-1
http://www.jegs.com/i/Edelbrock/350/77949/10002/-1 |
75 -
No idea what's going on, but if the manifold is too wide, could a machinist take it down to fit, or is it a configuration issue? Welcome to the world of hot rodding! Archer |
I'm telling you to start making calls.
Ships today http://www.jegs.com/i/Mopar-Performa...76128/10002/-1 Ships 9/27/16 http://www.jegs.com/i/Mopar-Performa...76129/10002/-1 What block are you using B or RB? If you have a B block. Manciniracng has three for a B block here is one. http://www.manciniracing.com/400sinplan41.html |
Thanks guys
Anything that fits a stage 6 wont work stage 7 because its alot shorter distance between the intake ports. The stage 6 stuff is too wide. There were some jntakes made to fit these but immediately discontinued. Im going to hit up racing teams etc on social media
What block are we mounting these too?
I will have to find out if its a b or rb but i beleive this 440 block came from a dodge monico
Ok... Please check.... I know those heads have the built in Spacers for the intake. I'm just trying to get square on what you need and what we are looking for before getting crazy..
Your just looking for a single carb intake? Not a cross ram or anything? Not like a true Max Wedge Intake for like a 413 or 426? |
Single plane, 4500 series....ill ask dad about that block today and get back to ya
I got a weiand open plenum
I remember seeing some with a 1/2" ???? spacer on the intake
