Need a Supercharger kit
Willing to buy a supercharger kit also wanting a 3 butterfly plate bird catcher scoop with it. also wanting a intake manifold cams and a aluminum head. LSD and 2 black seats.
What are you needing items for? engine? the 440 you mentioned elsewhere? LSD for which rearend? and seats for what?
It is the 440
It is the 440 engine.
Well are you wanting a centrifugal sc or a roots style? The Roots styled ones are mounted on the intake between carbs and motor the others are mounted with brackets normally from the heads... Maybe not any "kits" avail. I havent internet searched either.... As I suggested in your other post I think turbo would be the better option, but each to his own, and if you want a sc go for it...
