1967 Plymouth fury III muscle car, 383 commando
Old Oct 24, 2018 | 11:48 AM
Stephen Chen's Avatar
1967 Plymouth fury "sport" with a 383 commando big block. Car runs strong fire up first try. We just put $2,400 into it and need about another 12 to be top top. Engine is original not sure on exact mileage. Rear quarter panel has some surface rust and interior could use minor attention other than that this cruiser is good to go. The previous owner was a mechanic and chopped the top super clean job. Has custom wheels and a cover with frame.
No top, it's professionally chopped. The bars in the picture are a custom supports for the car cover. current reg good till end of year.
everything works on the vehicle an is street legal/drivable
the shift needle indicator detached, its the old style shifter
****. doesn't affect anything and is an easy fix.
as far as the latest work done to car end of 2017.
new fuel pump
new edelbrock carburetor
new fuel filter
new throttle lever
new carb adapter
new carb electrical
new battery cable clamps
new fuel hose and clamps
new battery
new radiator
thermostat and shroud bracket
A little info on the fury.
1967 Plymouth fury 3 "sport"
383 "commando" 4 barrel v8 engine
325 HP @2800 RPM
10 to 1 compression
4 bbl carb dual exhaust
2 snorkel air cleaner intake
3 speed automatic transmission
we run premium fuel
as you saw from the pics the car is in pretty good, condition with a lot of original parts.
as far as a few of the cosmetic things I had on the list to do over time.
upholstery
electric ignition
brakes and drums upgrade
Few things my mechanic suggested next on the list.
valve cover gaskets
pertronix
rear exhaust leak
surface exhaust manifold
I have paperwork and receipts for all work including tires and service.
all work from mechanic
the vin on the fury is
vin ps23g74170949
I hope this info help you get a better understanding on the condition and quality the fury is in.
there is a couple fury groups on Facebook you can join to better familiarize yourself you the fury culture.
$14,500
Stephen Chen
Oct 23, 2018 05:17 PM
barmaley
Sep 15, 2017 12:40 PM
blue 68 gts
Sep 25, 2010 01:16 PM
chucotownhotrodz
Mar 3, 2009 07:56 PM
DetroitDice
Jan 15, 2009 05:36 PM
