1967 Plymouth fury III muscle car, 383 commando
1967 Plymouth fury "sport" with a 383 commando big block. Car runs strong fire up first try. We just put $2,400 into it and need about another 12 to be top top. Engine is original not sure on exact mileage. Rear quarter panel has some surface rust and interior could use minor attention other than that this cruiser is good to go. The previous owner was a mechanic and chopped the top super clean job. Has custom wheels and a cover with frame.
No top, it's professionally chopped. The bars in the picture are a custom supports for the car cover. current reg good till end of year. everything works on the vehicle an is street legal/drivable the shift needle indicator detached, its the old style shifter knob. doesn't affect anything and is an easy fix. as far as the latest work done to car end of 2017. new fuel pump new edelbrock carburetor new fuel filter new throttle lever new carb adapter new carb electrical new battery cable clamps new fuel hose and clamps new battery new radiator thermostat and shroud bracket A little info on the fury. 1967 Plymouth fury 3 "sport" 383 "commando" 4 barrel v8 engine 325 HP @2800 RPM 10 to 1 compression 4 bbl carb dual exhaust 2 snorkel air cleaner intake 3 speed automatic transmission we run premium fuel as you saw from the pics the car is in pretty good, condition with a lot of original parts. as far as a few of the cosmetic things I had on the list to do over time. upholstery electric ignition brakes and drums upgrade Few things my mechanic suggested next on the list. valve cover gaskets pertronix rear exhaust leak surface exhaust manifold I have paperwork and receipts for all work including tires and service. all work from mechanic the vin on the fury is vin ps23g74170949 I hope this info help you get a better understanding on the condition and quality the fury is in. there is a couple fury groups on Facebook you can join to better familiarize yourself you the fury culture. $14,500 https://cimg9.ibsrv.net/gimg/moparfo...68b27d16ab.jpg https://cimg7.ibsrv.net/gimg/moparfo...324acc1e00.jpg https://cimg8.ibsrv.net/gimg/moparfo...a3222bb6f6.jpg https://cimg6.ibsrv.net/gimg/moparfo...27ba81ef60.jpg https://cimg5.ibsrv.net/gimg/moparfo...03bfe1ad94.jpg https://cimg3.ibsrv.net/gimg/moparfo...34037733d5.jpg https://cimg2.ibsrv.net/gimg/moparfo...841ca9c9d0.jpg https://cimg1.ibsrv.net/gimg/moparfo...4291fdf0c3.jpg https://cimg9.ibsrv.net/gimg/moparfo...04767fc8ce.jpg https://cimg0.ibsrv.net/gimg/moparfo...104dd51de5.jpg https://cimg6.ibsrv.net/gimg/moparfo...783c04f643.jpg https://cimg5.ibsrv.net/gimg/moparfo...76ec98622a.jpg https://cimg3.ibsrv.net/gimg/moparfo...6307592a6a.jpg https://cimg4.ibsrv.net/gimg/moparfo...c5e7e33e23.jpg https://cimg2.ibsrv.net/gimg/moparfo...0119db5ce.jpeg https://cimg0.ibsrv.net/gimg/moparfo...6583c6a997.jpg |
| All times are GMT -7. The time now is 04:43 AM. |
