Mopar Forums (/forums/)
-   A-Body (https://moparforums.com/forums/f9/)
-   -   1966 Plymouth Valiant Signet (https://moparforums.com/forums/f9/1966-plymouth-valiant-signet-237/)
Coolio9 Jun 4, 2007 08:27 PM
I want to do a Disc Brake Conversion from the stock drum brakes. anyone have any pointers on what i all need or anything that might be of any help at all. much appreciated:)
Jonah Hex Jun 20, 2007 09:51 AM
Coolio9,
Depending on what kind of money you are looking to spend, there are several ways you can go.
Disc set-ups from a `73 and newer a-body is one way to go. If you can find a doner car, take the calipers, spindles, and lower control arms, along with the master cylinder and propositioning valve. It is a bolt-on affair.
If you are willing to spend $800-1500, you could go with one of the aftermarket set-ups, such as Wilwood or MP Brakes.
Jonah
rpbryant Aug 5, 2009 01:35 PM
66 valiant
The other nice thing youlle get out of doing a disc conversion is, it will open up the variety of wheels you will be able to fit as it will change your lug pattern.
theomahamoparguy Aug 5, 2009 06:05 PM
If you gowith the 73-76 dart/valiant setup, make sure you get the upper control arm with the setup [from the 73-76] the newer setup uses a larger upper ball joint. If you find them impossible to remove {they can be a B*tch}, you can get new ones from Master Power Brakes.
phish1270 Aug 20, 2009 06:20 PM
Scarebird
There also is a company called Scarebird that makes disc brake conversion kits for drum brake cars. They offer a bracket that will bolt onto your drum brake spindle, preferably 10" drums I think. Then you buy Celebrity calipers & rotors along with Cadillac hoses, all pretty cheap. This is obviously not for diehard Mopar purists but it is the least expensive option. There are a few write ups on FABO. It also looks like the easiest to do.
theomahamoparguy Aug 20, 2009 06:24 PM
I never noticed that this is an old thread {original post} from 2007.
Oh well
