Mopar Forums (/forums/)
-   A-Body (https://moparforums.com/forums/f9/)
-   -   1970 340 duster steering components (https://moparforums.com/forums/f9/1970-340-duster-steering-components-6224/)
Jasonmiester May 17, 2010 06:26 AM
Hey, I am in the process of gathering parts for my restoration of a 70' 340 duster. I bought it as a shell. No interior no motor. Has the rear end, that's about it. So I'm gathering parts here and there. I bought two power steering columns off the Internet and a power steering gear box. But the column is too short. I don't know if I have the wrong column or wrong box?.. Does anyone know the full length of a power steering?
Any info is much appreciated thanks
Mr.Duster May 17, 2010 09:21 AM
how longs the steering column you have
Jasonmiester May 17, 2010 03:02 PM
Full length of the column is about 36'' from end to where it bolts down to the frame, is about 9''.
Jasonmiester May 17, 2010 03:22 PM
https://moparforums.com/forums/pictu...pictureid=1853
blue 68 gts May 17, 2010 06:52 PM
You must have a manual box from what I can figure..
blue 68 gts May 17, 2010 06:53 PM
And for some reason, it looks like youre missing something? The doogun on the end of the rod should be further out then that. I'll go check a column i have
Jasonmiester May 17, 2010 07:20 PM
if needed i can take a pic of the gear box too......if you can maybe send me pics of yours, i can give my email,,,thanks
blue 68 gts May 17, 2010 07:24 PM
Send me a PM with your email and I'll take a pic of my column and try to get you all the info you need.
My car was actually a power steering car, and I have a manual box in it. There are adapters you can buy, or you can change the rod in the column over.
Crazy4Carz.Com May 18, 2010 04:24 AM
The swivel on the end of that shaft should slide down about an inch or more from where it is.
Jasonmiester May 18, 2010 06:09 AM
Swivel is all the way out, I need about 11'' or so and it only goes to estmiate about 9''....
also its suppose to be a floor shift column, but it has that lever switch to me looks like a automatic column, but the guy I bought it from said it has something to do with the trans, it attaches to the trans for something......
