1971 Dart Disc brake conversion jegs kit?
Old Apr 23, 2011 | 05:47 PM
DeKees1's Avatar
for the jegs kit that i found is $419 shipped to my house. i have 10 inch drums in the front. its an A - body . duh.
http://www.jegs.com/i/JEGS-Performan...oductId=948838
Would this work without having to buy other things for my car. this would be nice bc to replace my drums is the same price.
Old Apr 23, 2011 | 06:34 PM
You would also need a disc master cylinder and a brake proportioning valve
Another option If you have any junk yards ? Get a later spindle with 5 on 4.1/2 bolt pattern.
And you can use disc rotor, caliper, backing plate & all the hardware from a Volare, Aspen Ok with stock 14" wheels. Or even the larger disc from a Marada, late 76, 77, 78 or simillar car if you use 15" wheels
Old Apr 24, 2011 | 08:17 PM
chlngr1970's Avatar
Double check that that kit will work with an A=Body, cause it says B & E body...
Have you checked to see if anyone in your area has a disc brake setup for a late A-Body?
j
Old May 9, 2011 | 06:07 AM
moparcharlie's Avatar
Red face re: disc brakes
You will need 73 + UP A-BODY UPPER CONTROL ARMS, in addition to the spindels, splash shields, & proporating valve, master cylinder.
check out my article on www.moparts.com look at the tech articles, there you will see my article, A-BODY DISC BRAKE CONVERSION
Mopar Charlie
Old Aug 17, 2011 | 07:51 PM
carbuilder19's Avatar
good thing I came across this thread. I now have all the answers to my questions about brake disc replacement I'll definitely visit this check out your article.
Mopar Charlie
I'm all good. thanks guys!
Old Aug 17, 2011 | 08:39 PM
Cazbah362's Avatar
Brakes
CarBuilder,
Funny thing is I ma currently in the process of upgrading my 71 Demon to 73-76 brakes. I bought them from a guy who sells them on ebay (hemi71x@aol.com) He has some of the Kelsey Hayes kit left. This would be a direct replacement for the 71 4" bolt pattern. I opted to go with the larger bolt pattern. I guess my point is he sells everything you need and or ensures you know what is needed. When I picked up my 73-76 setup he showed me the smaller bolt pattern setup, looked nice Not sure where you are from but he is in the Sac area, could save you shipping if you are in the area.
Good Luck
Old Aug 17, 2011 | 08:40 PM
Cazbah362's Avatar
Brakes
CarBuilder,
Good Luck
heminate
Aug 18, 2019 03:06 PM
Farmerbob
Jul 22, 2014 07:13 AM
Turbotarzan
Feb 26, 2014 08:53 AM
Hibred
Dec 29, 2009 07:25 PM
BTKBraden
Feb 22, 2007 11:31 AM
