273 with no stamp
I just purchased a 1965 Dart. It's a 273 car and the engine is also a 273 but the block was cast on 4-1-1969 and does not have any stampings either on the front of the block or down on the rail.
The heads and manifolds all appear to be correct for the car. So my theory is that the short block was replaced under warranty in 1969 or 1970. Does anyone know if my theory is plausible? Would it be normal for a 1969 short block to be devoid of stampings if it was shipped to a dealer's parts department? The block casting number is 2806030-273-3. |
Welcome to Mopar Forums.
I know Cheby did such things back in the day and for the life of me I cant remember if there was a "W" stamped in the block next to the casting #. They did something like that anyway. I don't believe I have ever seen a block with no casting #'s but what you say may be possible. Perhaps someone else has more insight on this. Just checking is your 5th # of your Vin a D ? Did you look just under the head on the front driver's side of the engine ? Some 273's came with only a 27 stamped in them. Let us know. |
Just checking is your 5th # of your Vin a D ? I have ever seen a block with no casting #'s |
Originally Posted by 65DartGTConv
(Post 32585)
No, my VIN is L452712131
Block has casting #'s but no stamps. |
are you sure its a 273 in there now?
they were enlarged to 318 in 67 i believe |
are you sure its a 273 in there now? they were enlarged to 318 in 67 i believe |
The -3 on the end of your casting #'s, could it be an S ? |
(Post 32643)
I crawled under there again. Definitely a 3.
| All times are GMT -7. The time now is 12:43 AM. |
