318 problem with CROSSWIND intake
Guest
Posts: n/a
Hi guys
I have 318 in my '68 barracuda. I did like they wrote in "Mopar Muscle http://www.popularhotrodding.com/enginemasters/articles/mopar/0667em_mopar_318_engine/index.html
I have a little problem with the intake manifold. It does not cover the coolant gate on the heads you can see this on the picture.
Have you ever seen this before, what to do with this ?
Last edited by kszysio; 03-05-2008 at 03:32 AM. Reason: http://img84.imageshack.us/img84/1552/intakefa5.jpg
First, I'm not familiar with this manifold, but there is some mention around the 'www that it's made in China, and that evidently some folks are getting poor quality control.
However, I don't understand where the leakage is. The only coolant present is the very front and very rear "ports" on the heads, for example, wehre the threaded hole is clear up out of the picture at top left.
Now, if you are referring to the uncovered hole in the middle top of the pic, near the carb, that is the head crossover casting, and has an "inner" hole that IS covered, so the uncovered hole near the carb is OK
Where is the thing leaking?
No, what I'm asking is for to clarify the problem. I do not understand where the leak is coming from?
Or are you indeed referring to the area that I described?
Can you "point" to where the leak is, in what part of the original picture that you posted?
OK, I wasn't too sure where you were referring to in the picture. The cropped picture I posted shows the hole that is part of the "heat crossover." That will not leak antifreeze, unlenss you have a cracked head.
I BELIEVE you can see the top of that cavity in the head on my old 340 factory intake on one side of the engine, just the way the casting was made
rcknrolfender79
03-11-2013 07:52 PM
waham87
02-22-2013 06:46 PM
