440 in a 1969 dart???
Who has done it and what issues will I need to address? It is a GT convertible 273ci model pretty much stock at this point.
Schumacher Creative is whom you should talk to. I have one in my 68 Dart. Big problems with power steering, power brakes and room in front of the water pump. Close to the radiator. But once you overcome some obstacles there is nothing like it.
well no power brakes and have already converted to electric fan. I did figgure the steering would be a MF how did they overcome that issue? were picking up the engine tomorrow.
They Convert to manual steering !
Is that a must? I figured it would come down to that....
Yes it is a must!! or a complete custom front sub frame with Rack & pinion $$$$ Spend the money for the TTI headers
There are several Mfg. http://www.magnumforce.com/store/det...&Search=&Page= |
i dont know how different they are but my brother did a swap in a dart swinger think it was a 75
the motor dropped right in used the same mounts locations as the original 318 he has to use manual brake set up but i think he used the power steering set up |
Originally Posted by Gorts 5th
(Post 92623)
Here's a real bad pic of mine but it is in there.
https://moparforums.com/forums/membe...0&ref=gnr-prev |
he also used the factory exhaust manifolds had to make his own exhaust pipe to get it out to the back
