6 speed Demon
I own a 1971 dodge demon and a totaled 1998 chevy z28 camaro. I'm looking to install the T56 6 speed transmission from my camaro into my Demon. I am wondering if anyone has done this conversion or if anyone knows where to get parts like bell housing and trans mount. Any help would be much appreciated. thanks
ive never seen it done...i dont know enough about that GM transmission. does the belt housing unbolt from the gearbox in a manner similar to the bell housing from an 833? are they similar in size?
The bell housing does unbolt from the gearbox like a normal manual transmission but they are a bit larger. It just seemed to me like this would be a common swap since from what I've heard the T56 was originally made for vipers and their v10's were originally 360ci small blocks with two cylinders grafted on which would make the bell housing bolt pattern the same.
I know that it's been years since the last post, but Modern Driveline has bell housings to adapt T5 and T56 transmissions to small and big block Mopars.
what is wrong with you GM belongs in a GM
